A master join to an AFM is failing over. There will be a pause in send/receive processing until the join is reconnected to a backup instance of the join partner.
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Warning
AFM Master join is failing over. MJ CB join index = %p1%
Name | Type |
p1 | xInt32 |
