This message is logged every time a dot1ag packet is transmitted on a set of ports. Note that mgmt is displayed if the port entry is not valid, this happens when the number of outgoing ports is less than 7
This message is for debug purposes only, and should only be enabled on request of Extreme Networks Technical Support.
Debug-Verbose
Transmitted %size% bytes cfm packet on vlan \"%vlan%\", and %ports% ports; %p1%, %p2%, %p3%, %p4%, %p5%, %p6%, %p7%
| Name | Type |
| vlan | VLAN |
| size | uInt32 |
| ports | uInt |
| p1 | egressSlotPort |
| p2 | egressSlotPort |
| p3 | egressSlotPort |
| p4 | egressSlotPort |
| p5 | egressSlotPort |
| p6 | egressSlotPort |
| p7 | egressSlotPort |
