cm.sys.msgErr
Description
Error decoding/encoding/sending the specified message from/to the remote peer.
Remedy
Communication between application peer failed due to error when decoding/encoding/sending the message. If it persists, an application restart or switch reboot maybe required to correct the problem and contact technical support, providing outputs of 'show switch', 'show log'.
Severity
Error
Message Text
Error %action% %msg%: Length %length% Peer %peer% (%name%)
Message Parameters
Name Type
action String
msg String
length sInt32
peer uInt32
name String
