LAGHC.SetAggrFail
Description
Message was not delivered to the aggregator preventing add/delete functions
Remedy
Check for valid LAG instance group ID and membership. If it is valid, try to see if the message is logged once the switch is rebooted.
Severity
Warning
Message Text
Setting the aggregator failed. Group %grpId% not sent, returned with %code%, to aggregator instead of %needed%.
Message Parameters
Name Type
grpId String
code uInt32
needed uInt32
