A conduit event message component failed to allocate a needed resource to manage the transmission and response for an internal switch message. The system is not functioning as expected.
This is possibly the result of memory leak at the Management module. Report the problem to your switch support contact.
Error
A request to allocate conduit add event information failed for slot %slotNo%, conduit type %cndtType%, conduit ID # %conduitIdNo%, and event seq. # %seqNo%.
| Name | Type |
| slotNo | uInt |
| cndtType | String |
| conduitIdNo | uInt16 |
| seqNo | uInt16 |
