A memory allocation failure occurred while processing a route from a BGP Peer. Information about the new route has been lost. The session to the BGP peer will be reset.
This is typically observed in scaled scenarios close to operating limits. try to reduce number of peers or routes stored. If functionality degrades, try disabling and enabling bgp or restarting the process. If problem persists, contact technical support with the following information: "show tech" and "upload debug". System restart may be required for continued operation.
Error
[VR %p1%] Failed to allocate memory while processing a route from a BGP Peer, index=%p2%
| Name | Type |
| p1 | uInt32 |
| p2 | xInt32 |
