cm.VSM.SetAppDataFail
Description
Setting application-specific data for the ISC had failed. In such a case, CM's MLAG mode functionality will not function properly.
Remedy
This is a rare condition which may be related to software, and may require a reboot of the switch to correct the problem. If it persists, contact technical support and provide outputs of 'show switch', 'show log'.
Severity
Error
Message Text
Unable to set application-specific data for ISC %isc%, Error = %err%
Message Parameters
Name Type
isc uInt16
err sInt
