This message indicates that an attempt to find an ISC port while leaking IGMP leave messages has failed.
Check the configuration on MLAG peer switches and ensure that it is consistent. Specifically check the IPMC configuration related to MLAG. On dual-MSM systems try failing over to the backup MSM. Stackables or single MSM systems may require a reboot to correct the problem. If the issue persists, please escalate to engineering.
Error
ISC port not found for VLAN %vlan%, ignore checkpoint message
| Name | Type |
| vlan | String |
