While performing work on an internal pseudo-wire table entry, the control block data used to manage the entry was found to be NULL.
Since the control block data was NULL, the affected pseudo-wire cannot be determined from the information available when the log was generated. If the affected pseudo-wire can be determined by some other method, disabling and enabling the L2VPN or CES container for the pseudo-wire may restore normal operation. To enable/disable an L2VPN, use the "enable/disable l2vpn" command. To enable/disable a CES, use the "enable/disable ces" command. If the problem continues, disabling and enabling MPLS will cause this internal table to be reset. To enable/disable MPLS, use the "enable/disable mpls" command.
Error
Control block data for a pseudo-wire was unexpectedly NULL in function %function%
| Name | Type |
| function | String |
