OS error while trying to write to an SCTP socket.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
SCTP Socket write error. Sockets error code = %p1% Socket ID = %p2% Stream number = %p3%
| Name | Type |
| p1 | sInt |
| p2 | sInt |
| p3 | uInt16 |
