HAL.PBB.MaxMsgEntExcd
Description
Construction of the specified PBB Tunnel message intended to be sent to I/O modules has failed. The limit on the number of entries that can packed in a single message has been exceeded. This is most likely caused due to memory corruption or due to a software bug.
Remedy
Contact Extreme customer support with details of the error message
Severity
Error
Message Text
%msg% pack failed - Number of entries %entries% exceeds size limit
Message Parameters
Name Type
msg String
entries uInt16
Applicable Platforms
