A component upon which VRRP depends did not initialize properly.
Check if CLI, CM backend, or VLAN is working properly. If it is, restart the VRRP process or reboot the switch.
Critical
%subsystemName% subsystem failed to initialize
| Name | Type |
| subsystemName | String |
