The metric for an IGP shortcut has been set to the minimum valid value. This is because the configured relative metric gives a total calculated metric value less than the minimum valid value.
No action required - Informational message only.
Debug-Summary
%p1% has set the metric for IGP shortcut %p2% to the minimum valid value %p3%. Diagnostic information: egress address %p4% configured metric %p5% path cost to egress %p6%
| Name | Type |
| p1 | String |
| p2 | String |
| p3 | uInt32 |
| p4 | VarFmtByteArray |
| p5 | sInt32 |
| p6 | uInt32 |
