RtMgr.delRtKernErr
Description
Route Manager failed to del a route from Kernel FIB table
Remedy
The exact remedy is dependant on the particular situation; but the problem may have been resolved by rejecting the request or performing some default action.
Severity
Error
Message Text
Fail to delete route to Kernel dst=%dst% mask=%mask% gateway=%gw% proto=%origin% metric=%metric%
Message Parameters
Name Type
dst IP
mask IP
gw IP
origin uInt
metric uInt
