VMT.BndPlcyFail
Description
Policy bind failed because the policy file has syntax errors, SMAC qualifier on ingress direction, or DMAC qualifier on egress direction.
Remedy
Check the policy for errors. If the policy needs to bind on ingress direction, then policy should not have an SMAC qualifier. Similarly, if the policy needs to bind on egress direction, then policy should not have a DMAC qualifier.
Severity
Error
Message Text
Policy name %plcyName% bind failed for %dir% direction.
Message Parameters
Name Type
plcyName String
dir String
