memory manager call could not allocate requested memory
This indicates that the switch is running low on memory resources. Reducing the size or complexity of the switch configuration may alleviate this issue. The rip process will need to be restarted. If the problem persists capture "show tech" output and contact customer support.
Critical
%caller% could not allocate %size% bytes of memory
| Name | Type |
| caller | String |
| size | uInt |
