An internal function was called with an invalid value. This condition is not expected and is indicative of a possible memory corruption due to a software bug that needs engineering attention.
Provide technical support information on overlay network configuration. Also, check the scalability limit and compare this with the current configuration.
Critical
Argument %arg% has an invalid value %val%
| Name | Type |
| arg | String |
| val | uInt32 |
