An attempt to send a VC FEC object failed. As a result, either a PW will not be established to the specified peer, or the status of an existing PW will not be sent to the peer.
There is no workaround for this problem.
Error
An attempt to send a VC FEC object for peer %peer% failed.
| Name | Type |
| peer | IPaddress |
