ERPS.AttachRingCntxtFail
Description
Ring context not attached. The hardware ring configuration, as a result, fails
Remedy
Check the ring that is being passed using 'show erps <ring>' command. Validate the ring. If problem occurs again, report to technical support as a software fault.
Severity
Error
Message Text
Failed to attach the ring context. Null ring pointer for ring Id %ringId% context%context%
Message Parameters
Name Type
ringId uInt32
context uInt32
