A MIB row in the bgpIpPreTable could not be deactivated because the route map to which it belongs is a non-exist or advertise map, and this route map has no other active IP prefixes. The attempt to deactivate the MIB row will fail.
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Error
Protocol Policy Manager could not modify a MIB row in the bgpIpPreTable because the route-map to which it belongs is an advertise or non-exist map, and has no other active IP prefixes. VR: %p1% Route Map Index: %p2% Route Map Number: %p3% IP Prefix Number: %p4%
Name | Type |
p1 | uInt32 |
p2 | uInt32 |
p3 | uInt32 |
p4 | uInt32 |
