ospf.spf.IgnAddRt
Description
Used when ospf ignores adding one route to kernel routing table. %ip%: the IP address of the destination. %mask%: the IP mask of the destination. %gw%: the next hope address of the route to the destination. %cost%: the cost to the destination. %area%: the associated area of the destination route. %proto%: the route type, it could be intra-area, inter-area, extern-1 or extern-2.
Remedy
None. This is for debugging.
Severity
Debug-Verbose
Message Text
Ignore adding dst %ip%/%mask% gw %gw% cost %cost% area %area% %proto%.
Message Parameters
Name Type
ip IPN
mask IPmaskvalN
gw IPN
cost uInt
area IPN
proto String
