Port states could not be set correctly due to a ring Id and group Id mismatch
use 'show erps' command to determine a valid ring being used. This is a software defect. Contact the technical support
Warning
Ring Id %ringId% does not match VLAN group Id %grpId%
| Name | Type |
| ringId | uInt32 |
| grpId | uInt32 |
