VLAN manager function returned an error for the tunnel port. This might happens due to timing.
No action required. If this causes a problem, contact technical support with the following information: configuration, and the "show log" output.
Debug-Summary
Tunnel with remote endpoint %dst% and local endpoint %src% port interface is not found.
| Name | Type |
| dst | IP |
| src | IP |
