EAPS PDU being dropped because the OUI value is invalid.
Possible programming error. May have to capture packet using sniffer, and comparing with packet data at sending stations egress port. If sending station's packet itself has incorrect OUI, then most likely programming error while packet being created. If the sending station's packet data differs from this packet, it would need further troubleshooting to isolate where in the network the OUI fields are getting modified.
Warning
%slotPort%, %vlan% - OUI (%oui0% : %oui1% : %oui2%) is invalid. Correct OUI is 00:E0:2B
| Name | Type |
| slotPort | SlotPort |
| vlan | VLAN |
| oui0 | xInt8 |
| oui1 | xInt8 |
| oui2 | xInt8 |
