Delete route failed for dest/mask via the nh, possible err are route node or route info not found for the route to be deleted.
This may not be an issue, as it may be hit when delete is tried for a route not found. Will need developer to take a look if that is not the case.
Debug-Data
Delete Route Failed for %addr%/%mask% via %nh% in vr=%vr%
| Name | Type |
| vr | VRID |
| addr | String |
| mask | IPmasklen |
| nh | String |
| err | String |
