An error counter is outside of its normal operating range.
If health check considers that the error is occuring frequently enough for the component to be considered to have failed, then it will reboot the card with the CompFailDetail message above. If not, then the ErrCntExcdNormRange message is a Warning but nothing specifically needs to be done about it.
Warning
Error counter %errorId% in %deviceName% on slot %slot% exceeds its normal operating range. Counter value of %count% errors in %pollInterval% seconds exceeds threshold of %threshold% error(s).
| Name | Type |
| deviceName | String |
| slot | uInt32 |
| errorId | String |
| count | uInt32 |
| pollInterval | uInt32 |
| threshold | uInt32 |
