An internal function was called with a NULL pointer. This condition is not expected and is indicative of a possible memory corruption due to a software bug that needs engineering attention.
Provide technical support information on the switch configuration. Also, check the scalability limit and compare this with the current configuration.
Critical
Argument %arg% is NULL
Name | Type |
arg | String |
