Management module is attempting to send a command, that is not defined. This is coding defect.
Repeat the QoS related configuration. If this error message is observed after reconfiguration, collect show tech output and contact Extreme Technical support.
Error
Unsupport qos command %action% value %value% qos %qos%
| Name | Type |
| value | uInt32 |
| qos | uInt8 |
| action | uInt16 |
