Could not allocate memory for KaY's Transmit Secure Channel (SC) object, which is required for MACsec.
This is an unexpected internal condition needing technical assistance. Check if sufficient memory is available and memory is not occupied by other processes: "show memory" "show memory process macsec" If the problem persists, contact technical support with the following information: "show tech-support"
Critical
Failed to create Transmit SC on slot %slotPort%
| Name | Type |
| slotPort | SlotPort |
