MACsec.PortMACsecUnSuprt
Description
This condition occurs when MAC Security (MACsec) is enabled on a port that does not support encryption. This may occur when an encryption-capable VIM is replaced with a non-encryption VIM
Remedy
If MACsec is desired then install a VIM that is capable of encryption, otherwise disable MACsec on the port.
Severity
Error
Message Text
MACsec is enabled on port %slotport% but port hardware does not support encryption
Message Parameters
Name Type
slotport SlotPort
Applicable Platforms
