HAL.Phy.FuncFail
Description
A function call to a hardware PHY device failed. This problem is usually due to a failure of accessing a hardware register. The hardware may be in a bad state. The error message gives the detail of the failure.
Remedy
The problem usually can be resolved by retrying the operation or power-cycling the switch or the card in the slot.
Severity
Error
Message Text
The call to %funcName% failed for phyId %phyId% retVal %rv%
Message Parameters
Name Type
funcName String
phyId uInt
rv sInt
