Received Health PDU on the Primary port. EAPS PDUs should never be received on its Primary Port. The PDU is dropped.
The most likely cause for this would be the Primary port is configured to be a load-shared trunk on this end, but it is not configured for load-sharing on its neighboring switch. Check configuration, and cabling on Primary port.
Warning
EAPSD %eapsD% - Received %pduType% on port %slotPort% which is the Primary port.
| Name | Type |
| eapsD | EAPS-domain |
| slotPort | SlotPort |
| pduType | String |
