This message is logged every time a dot1ag packet could not be transmitted. The error code returned is the standard Linux errno value. Note that mgmt is displayed if the port entry is not valid, this happens when the number of outgoing ports is less than 6
This message is for debug purposes only, and should only be enabled on request of Extreme Networks Technical Support.
Debug-Summary
Transmitted %size% bytes cfm packet failed on vlan \"%vlan%\", and %ports% ports; %p1%, %p2%, %p3%, %p4%, %p5%, %p6%, error %error%
| Name | Type |
| vlan | VLAN |
| size | uInt |
| ports | uInt |
| p1 | egressSlotPort |
| p2 | egressSlotPort |
| p3 | egressSlotPort |
| p4 | egressSlotPort |
| p5 | egressSlotPort |
| p6 | egressSlotPort |
| error | sInt |
