Management module failed to initialize conduits for QoS
The switch will be unable to send QoS configuration to the IO slot. Reboot the switch. If the problem persists, contact Extreme Technical support.
Error
Management module failed to create conduits for QoS. Create conduits failed with return code %returnCode%
| Name | Type |
| returnCode | sInt32 |
