Edge Automation was not able to successfully parse an internal message. This condition is not expected and is indicative of a possible memory corruption due to a software bug that needs engineering attention.
Provide technical support information on the switch configuration using the 'show tech-support' command.
Critical
Failed to parse message %format%
| Name | Type |
| format | Printf |
