A Hello PDU of the specified type either did not include an authentication TLV or included an authentication TLV but the password was incorrect.
This error message may result from transitioning to different passwords in the topology. If the message persists and authentication is desired ensure the correct password has been configured on the neighboring routers. If authentication is not desired disable IIH authentication on this switch using the unconfigure area [area_name] area-password command.
Warning
%pduType% authentication failure
| Name | Type |
| pduType | String |
