Rejected a request to open a multicast socket to connect or listen.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Invalid open mcast socket request. Must not be set to connect or listen. Application socket handle = %p1% Socket type = %p2% Socket family = %p3% Socket protocol = %p4% Socket action flags = %p5%
Name | Type |
p1 | uInt32 |
p2 | xInt32 |
p3 | xInt32 |
p4 | xInt32 |
p5 | uInt32 |
