This event indicates that a MPLS RSVP LSP bandwidth has been successfully updated. The system is functioning as expected.
N/A.
Debug-Data
Bandwidth update: req. size = %bandwidth% kbps. hold pri. = %hold_pri%. intface = %if_name%. seg type = %upd_type% set pri = %set_pri% lsp_index = %xc_index%
| Name | Type |
| hold_pri | uInt32 |
| bandwidth | uInt32 |
| if_name | String |
| upd_type | String |
| set_pri | uInt32 |
| xc_index | uInt32 |
