The RADIUS server returned these authorization values for the user with userName on the indicated port: Access Level ("Read-Write", "Read-only", "Framed" or "unknown"), Tunnel Type ("none", "vlan" or "unknown"), Tunnel Medium ("none", "802" or "unknown"), Tunnel Group Id (vlan identifier), Session Timeout (session timeout value in seconds) Idle Timeout (idle timeout value in seconds), FilterId (Policy FilterId), VrName (VR to use for dynamically created vlans), and NSI Type/ID (used for Dynamic VxLan). This message indicates that these attributes and their respective values were returned from the RADIUS server but does not guarantee that the authenticating agent will use them.
No action required - Informational message only.
Debug-Summary
Authorization values for %user%(userName '%userName%') on port %port%: Access level - %accessLevel%, Tunnel Type - %tunnelType%, Tunnel Medium - %tunnelMedium%, Tunnel Group Id - %tunnelGroupId%, Session Timeout - %sessionTimeout%, Idle Timeout - %idleTimeout%, FilterId: %filterId%. VrName: %vrName% NsiType: %nsiType% NsiId: %nsiId%
| Name | Type |
| user | AccountName |
| userName | AccountName |
| port | SlotPort |
| accessLevel | String |
| tunnelType | String |
| tunnelMedium | String |
| tunnelGroupId | uInt32 |
| sessionTimeout | uInt32 |
| idleTimeout | uInt32 |
| filterId | String |
| vrName | String |
| nsiType | uInt32 |
| nsiId | uInt32 |
