This event occurs whenever inter-thread message send failed. vrId: VR ID object: Object to be sent
This is a rare internal condition needing technical assistance. It should be fixed by reset running OSPFv3 settings with CLI commands "disable ospfv3/enable ospfv3", if not, try restart the OSPFv3 process with CLI command "restart process ospfv3", or reboot the system. If the event still occurs after reboot, contact technical support with the following information: "show tech" command output."
Error
VR %vrId%: Failed to send %object% to protocol thread.
| Name | Type |
| vrId | VRID |
| object | String |
