HAL.VXLAN.VNetHwResrcReduc
Description
Hardware resource for the displayed object is impacted by resource reduction. This will result in incorrect programming of hardware tables and will impact forwarding.
Remedy
Check the run-time scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim the resource.
Severity
Error
Message Text
Virtual network hardware resource reduction causes virtual network with internal id %vpnId% to be invalid.
Message Parameters
Name Type
vpnId uInt32
