Failed to register the socket as an N-BASE work source.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
An internal resource shortage caused an incoming connection to fail. Socket ID = %p1% Socket type = %p2% Socket family = %p3% Socket protocol = %p4% Application handle = %p5% Stub socket handle = %p6%
Name | Type |
p1 | sInt |
p2 | xInt32 |
p3 | xInt32 |
p4 | xInt32 |
p5 | uInt32 |
p6 | uInt32 |
