The message indicates the failure in removing a Customer VLAN from the floodin group of the VLAN or the I-SID. Lower the severity to narrow the cause of failures. The cause could be in the PSI library or the low on memory in the system.
Retry the configuration so that the ports are re-deleted from the flooding group of I-SID or VLAN.
Debug-Summary
Failed to remove CNP ports in VLAN %vlanName% from PSI of I-SID %isidName% when %info%.
| Name | Type |
| vlanName | String |
| isidName | String |
| info | String |
