Failed to get packet information. Note: If the traced error number, %2, is 0 then the IP stack did not provide the required ancillary data.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Warning
Failed to get packet information using IP_PKTINFO or IPV6_PKTINFO. Socket = %p1% recvmsg error code (or 0 if none) = %p2%
| Name | Type |
| p1 | xInt32 |
| p2 | uInt32 |
