MACsec.PDU.ParmSetDistSAKHdr
Description
This message displays the contents of a transmitted or received MKPDU's Distributed SAK Parameter Set Header Each MKA PDUs (MKPDU) contains a sequence of "parameter sets": Basic, Live Peer List, Potential Peer List, SAK Use, Distributed SAK. The Distributed SAK Parameter Set Header is sent by the Key Server immediately after it generates a new SAK or decides to not use MACsec. AN (Association Number): range 0 to 3 Confidentiaty Offset: 0=No Confidentaility 1=Confidentiality w/Offset 0 2=Confidentiality w/Offset 30 3=Confidentiality w/Offset 50 Body Length: 0=Key Server decided to not use MACsec (i.e., MKA without MACsec) >0=Key Server decided to use MACsec. Key info will be in ParmSetDistSAKBdy. Further details on MKA parameter sets and parameters can be found in Clause 11.11 EAPOL-MKA of IEEE Std 802.1X-2010.
Remedy
No action required - Informational message only.
Severity
Debug-Verbose
Message Text
%direction% MKPDU on port %slotPort% [Distributed SAK] AN:%an% Confidentiality Offset:%confOffset% Body Length:%bodyLen%
Message Parameters
Name Type
slotPort SlotPort
direction String
an uInt
confOffset uInt
bodyLen uInt
Applicable Platforms
