An optic module of a particular type has been inserted into a port of a type with which it is not compatible. The optic module can not and will not work in the specific port.
Remove the incompatible optic from the port and replace it with one that is supported in that port.
Warning
The %optic% optic module is not compatible with %portType% ports - please remove it from port %slotPort%.
| Name | Type |
| optic | String |
| slotPort | SlotPort |
| portType | String |
