BFD received an IPS over the BFDI from an unknown join partner. The IPS was ignored.
If BFD is being brought down, this log is normal and should be ignored. Otherwise, gather diagnostics and investigate.
Warning
BFD ignored a stale message across the BFDI from an unknown partner. BFD entity index = %p1% Sender process ID = %p2%
| Name | Type |
| p1 | sInt32 |
| p2 | uInt32 |
