LDAP client could not successfully connect to the LDAP server.
Check if the LDAP server is up and running. Verify that the LDAP configuration on the switch matches with the LDAP server configuration. Check the connectivity to the LDAP server.
Error
Connect to LDAP server %serverIP% failed
| Name | Type |
| serverIP | String |
