NetDBMgr.AllocEventBaseFail
Description
netDbMgr process failed to allocate an event base. Event base allocation failures is indicative of the system being low on memory.
Remedy
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim memory. Once sufficient system memory is reclaimed, it is recommended that netDbMgr process be restarted for internal state to be fully rebuilt.
Severity
Error
Message Text
Failed to allocate a event base: %name%
Message Parameters
Name Type
name String
