BGP.RIBMgr.ClrStatsNbrPeerMIBFail
Description
Failed to clear statistics for Neighbor Peer MIB. This is likely to be due to incorrect use of the MIB interface. This can happen if a SET for the peer MIB is sent without first sending a TEST, or if the TEST preceding the SET did not indicate that the statistics should be cleared. The peer statistics will not be cleared.
Remedy
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Severity
Error
Message Text
Failed to clear statistics for neighbor peer MIB. VR = %p1% Local IP address = %p2% Remote IP address = %p3%
Message Parameters
Name Type
p1 uInt32
p2 VarFmtByteArray
p3 VarFmtByteArray
